Magneto drive identification
Jonny Eriksson
Topic author - Posts: 32
- First Name: Jonny
- Last Name: Eriksson
- * REQUIRED* Type and Year of Model Ts owned: 1914 RB
Does anyone know what kind of magneto drive this is? Its not Matco or columbo. It has to much angle.
Last edited by Jonny Eriksson on Fri Jan 24, 2025 1:02 pm, edited 1 time in total.
Jonny Eriksson
- First Name: Jonny
Re: Magneto drive identification
First I thought it was a fordson accessory but it was way to big.
Last edited by Jonny Eriksson on Wed Jan 22, 2025 4:08 am, edited 1 time in total.
Jonny Eriksson
- First Name: Jonny
Jonny Eriksson
- First Name: Jonny
This is a Matco drive and has to little angle to be the one Im looking for.
Are you trying to buy one like in the old photo?
Must be some reason to want that specific magneto drive?
The Fordson one you show tied onto a T engine with string was probably made by Bosch, and they did build a shorter version for the model T engine. While the Bosch Fordson and several others made for model Ts (including the Matco) are fairly common, over the years I have seen barely a handful of that style Bosch magneto drive for the model Ts. A couple other Bosch styles are also fairly common.
And no, I don't know of any available.
Jonny Eriksson
- First Name: Jonny
Wayne, I´m recreating this car, so I hope someone can identify this magneto drive so I can start searching for one to buy.
Wonder if it's home made? I would suggest asking on the general forum, you will get a lot more eyes on the question then here in the classifieds.
See if this helps.
See if this helps.
- Attachments
- IMG_2304.png (197.41 KiB) Viewed 2372 times
nigel_hugo
- First Name: nigel
- Last Name: hugo
- * REQUIRED* Type and Year of Model Ts owned: 1911 T touring car
I think it maybe a Lucas unit. I know of 2 vehicles in the UK who have them installed but I can't find any pictures. Nigel Hugo.
Layden Butler
- First Name: Layden
- Last Name: Butler
Jonny Eriksson
- First Name: Jonny
Layden Butler!
Thank you! I strongly believe in Parkin! Is yours for sale?
