Side drive magneto adapter
Playswithbrass
Topic author - Posts: 142
- First Name: Peter
- Last Name: McIntyre
- * REQUIRED* Type and Year of Model Ts owned: 1913 Speedster
Price 500.00 u.s.plus postage
Removed from a running engine,reason for removal,went to a cross drive due to installing different intake/carb and header set up.
Comes with all hardware/spacers etc. that held adapter to engine
Playswithbrass
- First Name: Peter
Re: Side drive magneto adapter
Kevin Pharis has contacted me and advised me that the hard to find 12/to early 13 front timing gear cover that I removed should be included in this sale. This makes a complete package to install a side drive mag. Thanks Kevin for the guidance. Pete
Peter, thank you for acknowledging help given. Not every seller sees value in others helping to identify/date/advise on items posted. It is as though the classifieds are sacrosanct, and it should be left to the buyer to make a blunder and wear the consequences.
Adam
- First Name: Adam
- Last Name: Doleshal
Allan wrote: ↑Tue Jan 28, 2025 10:41 pmPeter, thank you for acknowledging help given. Not every seller sees value in others helping to identify/date/advise on items posted. It is as though the classifieds are sacrosanct, and it should be left to the buyer to make a blunder and wear the consequences.
Yes, but Kevin went about it the proper and courteous way, BY CONTACTING THE PERSON WHO POSTED THE AD DIRECTLY. Not by posting his “two cents worth” to someone else’s classified. This is the classified area, not a discussion forum.
Playswithbrass
- First Name: Peter
Straight up guy Kevin is!
Adam
- First Name: Adam
He certainly is.
FYI to whoever buys this: I’ve re-machined several of that style front cover over the years for a modern cam seal and it works well. There is no need to stick with that odd captured felt seal. Contact me if interested in having it done.
Playswithbrass
- First Name: Peter
Anybody up to dickering,is my price too high? Lets talk cheers pete
Playswithbrass
- First Name: Peter
Anybody out there,need this drive?
Playswithbrass
- First Name: Peter
Price drop 450.00 u.s. plus postage
Ron_White
- First Name: Ron
- Last Name: White
Hi Peter
Are the gears intact and in good shape?
TIA
TIA
