Looking for a pair of axle Gears for my '15 roadster. Mine are pretty worn out. To be installed on new axles.
Phil
Axle Gears Wanted
Ken Buhler
- First Name: Ken
- Last Name: Buhler
- Board Member Since: 2012
Re: Axle Gears Wanted
Phillip,
Make sure the gear shoulder is 1.807 or very near to it.
Work honestly
Stay true to your word
Get the job done right
Art M
- First Name: Art
- Last Name: Mirtes
Are they the same as those in a 26 axle. I am assuming the gears at the ones pressed onto the axle shaft.
Art Mirtes
Art Mirtes
mortier
Topic author - Posts: 109
- First Name: Philip
- Last Name: Jamison
- * REQUIRED* Type and Year of Model Ts owned: 1915 Roadster
Yes, I believe they are the same gear I '26. At least the axles are the same from 1911-1927.
Phil
Phil
Karl Von Neumann
- First Name: Karl
- Last Name: VonNeumann
- * REQUIRED* Type and Year of Model Ts owned: 1916 touring 1927 tudor 1926 hotrod 1913 speedster (project) 1926 coupe (project)
- Board Member Since: 2022
mortier
Thanks! I found some gears.
Phil
Phil
