Axle Gears Wanted
mortier
First Name: Philip
Last Name: Jamison
* REQUIRED* Type and Year of Model Ts owned: 1915 Roadster
Axle Gears Wanted
Post by mortier » Thu Feb 13, 2025 3:31 pm
Looking for a pair of axle Gears for my '15 roadster. Mine are pretty worn out. To be installed on new axles.
Phil
Ken Buhler
First Name: Ken
Last Name: Buhler
Board Member Since: 2012
Re: Axle Gears Wanted
Post by Ken Buhler » Thu Feb 13, 2025 4:41 pm
Phillip,
Make sure the gear shoulder is 1.807 or very near to it.
Work honestly
Stay true to your word
Get the job done right
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Thu Feb 13, 2025 4:57 pm
Are they the same as those in a 26 axle. I am assuming the gears at the ones pressed onto the axle shaft.
Art Mirtes
mortier
First Name: Philip
Last Name: Jamison
Post by mortier » Thu Feb 13, 2025 5:34 pm
Yes, I believe they are the same gear I '26. At least the axles are the same from 1911-1927.
Phil
Karl Von Neumann
First Name: Karl
Last Name: VonNeumann
Board Member Since: 2022
Post by Karl Von Neumann » Thu Feb 13, 2025 10:54 pm
I'll check Saturday for some
mortier
First Name: Philip
Last Name: Jamison
Post by mortier » Fri Feb 14, 2025 12:09 pm
Thanks! I found some gears.
Phil
