WTB 26/27 Roadster front seat base
JonLevine
Topic author - Posts: 30
- First Name: Jon
- Last Name: Levine
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster Pickup
- Board Member Since: 2022
I am looking to buy the front seat base assembly for a 26/27 Roadster. I know these parts were being manufactured by Howell’s Sheetmetal and sold by them and a few vendors but that appears to no longer the case. Either new old stock or original parts will work.
thanks!
thanks!
JonLevine
- First Name: Jon
- Last Name: Levine
Re: WTB 26/27 Roadster/Pickup Parts
to the top
JonLevine
- First Name: Jon
- Last Name: Levine
to the top
JonLevine
- First Name: Jon
- Last Name: Levine
Re: WTB 26/27 Roadster front seat base
to the top
Ken Buhler
- First Name: Ken
- Last Name: Buhler
- Board Member Since: 2012
Jon,
All of the 26/27 open cars have what you are looking for.
Work honestly
Stay true to your word
Get the job done right
JonLevine
- First Name: Jon
- Last Name: Levine
Thank you for your reply. So you are confirming that the Roadster and the Touring share the same front seat base? I have an opportunity to buy an NOS Howells seat base for a Coupe and see if I can modify it to work. Any idea how different that would be? I also wonder about using the seat base for a 28 Model A Roadster as it looks very similar to the 26/27 Roadster base in pictures. Thoughts about that?
- First Name: Henry
- Last Name: Lee
John,
Do you have an old one? I can reconstruct one from there if needed!
Hank
Hank
JonLevine
- First Name: Jon
- Last Name: Levine
Thanks for your reply Hank, but unfortunately I do not. I’m building a 26 Roadster Pickup from parts and while I was fortunate to find a very solid body, the seat structure was missing from it.
- First Name: Henry
- Last Name: Lee
Jon do you have all the heavy metal gauge support brackets on the sides and just require the sheet metal light weight piece?
Hank
Hank
JonLevine
- First Name: Jon
- Last Name: Levine
no I need the entire structure that supports the seat bottom
micshotrodgarage
- First Name: michael
- Last Name: miller
- * REQUIRED* Type and Year of Model Ts owned: 1926 & 27 Roadsters 1927 Roadster pickup
Hi John, Are you still looking for a 26 roadster seat base? Let know I think I could help. E mail would be fine...Mike
micshotrodgarage
- Last Name: miller
Hi John, Are you still needing a roadster seat structure? Let know I may be able to help. Mike
JonLevine
- First Name: Jon
- Last Name: Levine
Thanks Mike, yes very much so.
Jon
Jon
