WTB cylinder head outlet for 1915
johnr
Last Name: Delamater
* REQUIRED* Type and Year of Model Ts owned: 1927 Depot Hack
Post by johnr » Mon Mar 31, 2025 2:53 pm
Looking for a cylinder head outlet part #3004.
If you have one you want to sell let me know.
If you could include shipping to 44839 in the price.
Thank you.
Re: WTB cylinder head outlet for 1915
Post by TRDxB2 » Mon Mar 31, 2025 3:23 pm
Opps was looking at your profile not the heading. both are gone
Ralph F
First Name: Ralph
Last Name: Fitz-Gerald
Post by Ralph F » Mon Mar 31, 2025 3:35 pm
Frank I’m also looking for one.
Fitz
Ralph F
First Name: Ralph
Post by Ralph F » Tue Apr 01, 2025 7:56 pm
Still looking
Fitz
TFan
First Name: Jim
Last Name: Riedy
Post by TFan » Wed Apr 02, 2025 10:12 pm
John, are either one of these what you are looking for? I see no numbers or markings. Jim
johnr
Post by johnr » Thu Apr 03, 2025 4:19 pm
Jim
They appear to be for late date.
I am looking for earlier, 1915 to 1909 I think which were used with
brass era radiator.
Also I am not that far away from you.
Thank you .
John
Post by Wayne Sheldon » Thu Apr 03, 2025 5:11 pm
In the "For whatever it is worth" department? And - - - shhhhh, don't tell anyone?
The brass era outlets to the radiator have been hit and miss for many years. Reproductions have been made and sold in significant numbers. The original brass era necks were cast iron, a bit short, a bit thin, and often rusted away to too short to be usable. A lot of the reproductions have been cast in brass to avoid the trouble with rusting away.
These necks seem to be available at some times, and at other times they just don't seem to be available at all.
So, what I did a few years back. I was putting together two engines for a couple of my brass era T projects. I had one, a NOS original era APCO replacement neck that had never been installed. Other than the APCO name being cast onto the base, and a slight variation in the bolt holes intended to make installation easier, the size, shape, and fit of the APCO one was identical to a Ford original.
That was all well and good. However, it was the only one I had, and my attempts at that time to acquire another one for the second engine found nothing. But I had a small box with several common later model T Ford upper radiator necks.
Using the APCO as my guide, I carefully found the right spot, drew lines, and cut a pie wedge shaped piece out of the bend. I positioned the cutout to leave a natural looking bend between the base and the neck, and shortened the remaining neck to fit the short reach required in the brass era Ts. I ground a wide "V" where the pieces needed to be joined, and brazed them together, adding some additional coverage on the inside (easy to do as it was right near the base opening) for added strength.
Filed roughly (not supposed to be a fine finish), installed, and painted? Can't tell it from an original brass era neck.
Just a suggestion.
Getting it just right, it would help if you can borrow an original one from someone to compare with.
Post by TRDxB2 » Thu Apr 03, 2025 11:30 pm
The differences
Repros
SOLD original 1915
Walt Wise
First Name: Walt
Last Name: Wise
Post by Walt Wise » Mon Apr 07, 2025 2:52 pm
Some just listed on T-Bay, no connection to the ad whatsoever...
https://www.ebay.com/itm/256885657797?_ ... R8bMgpTCZQ
Last Name: Tannehill
Board Member Since: 2002
Post by JTT3 » Mon Apr 07, 2025 5:20 pm
Well that was quick.
Kenny Edmondson
First Name: Kenny
Last Name: Edmondson
* REQUIRED* Type and Year of Model Ts owned: 1923 Touring 1924 Roadster PU
Post by Kenny Edmondson » Tue Apr 08, 2025 11:22 am
Here’s one I have. Sent you an email also.
