Timer cover 1911-1919
ModelT46
First Name: Darel
Last Name: Leipold
Post by ModelT46 » Fri Apr 04, 2025 11:59 am
Here is a early time cover, perhaps 1911-1915. If you know the exact year, post that here. The cover is $75 plus the ride. I will consider offers.
cover back.JPG (114.97 KiB) Viewed 882 times
cover ft.JPG (113.48 KiB) Viewed 882 times
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: Timer cover 1911-1919
Post by Kevin Pharis » Sat Apr 05, 2025 10:34 am
Late ‘12 to early ‘13 timing cover with “small” oil scoop. This is also the cover that works with the 3 gear Bosch magneto side drive
RGould1910
Last Name: Gould
Post by RGould1910 » Sun Apr 06, 2025 12:22 am
See how it also has a u shaped channel for holding the fely
