Cushion spring rivets
Steves Ts
First Name: Steven
Last Name: Meudt
* REQUIRED* Type and Year of Model Ts owned: 1913 touring / 1913 delivery / 1917 roadster / 1914 roadster pick up
Post by Steves Ts » Fri Apr 04, 2025 7:53 am
Wtb, looking to purchase cushion spring rivets. Does anybody know where i can find these special rivets ?
Steve Meudt
Re: Cushion spring rivets
Post by Mark Gregush » Sat Apr 05, 2025 11:04 am
Loop or split pin? Both can be found by doing a search using upholstery buttons for tufting or just upholstery buttons.
Or do you mean for the points and if so, for what year and brand of coils?
If points, you might be better off just buying new point sets.
jab35
Last Name: Bartsch
Post by jab35 » Sat Apr 05, 2025 12:16 pm
Hi Steve: McMaster Carr may have something for you. I don't remember the diameter and length specs for the cushion spring point retainer, these brass semi-tubular rivets might be too large, hope this helps you, good luck, jb
https://www.mcmaster.com/products/rivet ... pe~hollow/
Steves Ts
First Name: Steven
Last Name: Meudt
Post by Steves Ts » Sat Apr 05, 2025 7:14 pm
Thanks Folks for Your reply's. I should have been more specific on type application. I have different types of coils I would like to replace the points with good used points. However the rivets on some of the points have collapsed rivets which I would like to "save". I'll try McMaster Carr.
