Bosch manual advance distributor ( spoken for ...thanks MTFCA)
Topic author - Posts: 1040
- First Name: Gene
- Last Name: French
- Board Member Since: 2014
Bosch distributor with manual advance ... advance works smoothly and distributor housing is in good condition ... will need cleaning and lubrication ... cap and rotor are good , points will need replacement or filing to clean contact surfaces ... drive gear is good ... price is $200 + $19.15 postage in lower 48 states , actual postage outside this area or INTERNATIONAL ...contact thru MTFCA site ...Gene French
- First Name: Gene
- Last Name: French
Re: Bosch manual advance distributor
to the top ...thanks MTFCA
- Last Name: Berger
Good morning Mr. French I would like to purchase your Bosch distributor. do you take Pay Pal. you can respond to me at JLBLJB@AOL.COM Thanks Jerry Berger
