TRADE ONLY flip style Fatman wheel
Topic author - Posts: 674
- First Name: Karl
- Last Name: VonNeumann
- * REQUIRED* Type and Year of Model Ts owned: 1916 touring 1927 tudor 1926 hotrod 1913 speedster (project) 1926 coupe (project)
- Board Member Since: 2022
I have this flip style Fatman steering wheel I'm looking to trade for a slide style wheel I will not sell mine unless you give me stupid money
Re: TRADE ONLY flip style Fatman wheel
That's a Bauer - you're referring to a Neville - good luck on that !!!
- Last Name: Francis
- * REQUIRED* Type and Year of Model Ts owned: 22 Runabout
That will not fit a Model T. For aModel T it needs a hum that goes over the steering cap will add photo laterSouth Park Zephyr wrote: ↑Tue Apr 15, 2025 7:12 amThere is one on eBay with about 3 1/2 days left
https://www.ebay.com/itm/256890405851
The correct Neville "Slider" for a Model T has the same profile as a stock wheel - the rim is below the spyder. The one Frank listed could possibly be used if the mounting hole is 3/4" - I've seen that type on a Model T but they look peculiar !
These re the two types that I am aware of made for a Model T.
One is for easy access to throttle & advance levers
- Attachments
- neville 2.jpg (80.48 KiB) Viewed 1469 times
- 132710.jpg (56.11 KiB) Viewed 1469 times
- First Name: Karl
For reference I'm running a dodge column in my couoe takes the same shaft size as the T so I could care less either way
