Metal Battery Box and Wood Battery Box
NBD925
First Name: Adam
Last Name: Corts
* REQUIRED* Type and Year of Model Ts owned: Touring 1922
Post by NBD925 » Sun Apr 20, 2025 12:22 pm
I have a 1922 Touring Car and need some parts for the battery area.
Wood Box
Metal Box
Correct Lid
Is Larry Smith still around and how do you buy a metal battery Box from him?
Last Name: Strange
Re: Metal Battery Box and Wood Battery Box
Post by CudaMan » Sun Apr 20, 2025 12:50 pm
Yes, Larry Smith is still around, you can contact him via PM to "original_smith" on this site. I don't know if he is currently offering metal battery boxes. You would still have to find an original lid, they aren't reproduced by anyone that I know of.
Here is an older post regarding battery boxes, including dimensions if you want to try and make your own: https://mtfca.com/phpBB3/viewtopic.php?t=24099
WorldChamp1914
First Name: Gary
Last Name: Hagen
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring and a 1921 Sightseeing Bus.See SF On a Dime
Post by WorldChamp1914 » Sun Apr 20, 2025 1:04 pm
I could use some clips
Last Name: Strange
Post by CudaMan » Sun Apr 20, 2025 2:10 pm
Post by Allan » Tue Apr 22, 2025 3:20 am
Adam, you need a metal battery box and the lid with the rounded edges to suit your 22 model. The wooden battery "box' was actually the battery case into which the plates and acid were fitted. Today the battery case is plastic. Between the wooden case and today's plastic ones, the cases were made of hard rubber.
Post by Original Smith » Tue Apr 22, 2025 1:08 pm
I'm not having the metal lower battery boxes made any more. They were exact copies of the originals. The current offerings are not 100% correct, and will not work with an original top.
NBD925
First Name: Adam
Last Name: Corts
Post by NBD925 » Fri Apr 25, 2025 5:38 pm
Dang! Im always late to the party. Do you have a line on one or know anyone that might have one?
