WTB - Atlas water pump - found
ewdysar
Topic author - Posts: 374
- First Name: Eric
- Last Name: D
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1915 Speedster #32, 1916 Touring, 1927 Runabout
I'm looking for an Atlas water pump, as seen in this photo:
Does anybody have one gathering dust on the shelf?
Keep crankin',
Eric
Keep crankin',
Eric
- First Name: Henry
- Last Name: Lee
Re: WTB - Atlas water pump
Eric I have a restored one but the mounting bracket has been cut down for a special project that did not go as planned. Can be easily made from sheet steel.
Hank 4two38three75seven09
ewdysar
- First Name: Eric
- Last Name: D
email sent, Hank.
ewdysar
- First Name: Eric
- Last Name: D
Re: WTB - Atlas water pump - found
Done deal. Thanks, Hank!
I most likely have an original mounting plate, if you need one - I have a box full of Atlas circulators !
ewdysar
- First Name: Eric
- Last Name: D
Thanks Steve.
I'll keep that in mind when everything is coming together. I hope that this will be one of the answers for getting Robin Pharis' #32 back on the road with a "C" crank and Roof 8 "Liberty" head. However, all the mounts are custom (motor, R&P steering, suspension, radiator, etc.), so I'll have to see where the pump end of the engine sits, relative to the radiator, once all of these bits and pieces come back together.
Keep crankin',
Eric
Keep crankin',
Eric
elliott1936
- First Name: Tom
- Last Name: Elliott
- * REQUIRED* Type and Year of Model Ts owned: 1921 Speedster 1927 speedster
Eric:
Thanks for the purchase. I like the idea that you are working on speedster32 so fast.
Tom
Tom
ewdysar
- First Name: Eric
- Last Name: D
The Atlas is in my hands. Thanks Hank! On to the next challenge...
Keep crankin',
Eric
Keep crankin',
Eric
