WTB 1914 Block, Bill Everett
Topic author - Posts: 302
- First Name: Bill
- Last Name: Everett
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1914 Touring, 1912 Roadster PickUp in process
- Board Member Since: 2011
I would like to buy a block with a casting date between 9-1-13 - 12-15-13.
Let me know what you have and text me a couple of pictures to 901-496-8795.
Thanks.
Bill Everett
Cell: 901-496-8795
Thanks.
Bill Everett
Cell: 901-496-8795
Re: WTB 1914 Block, Bill Everett
I believe I have complete 11/13 engine that was powereing a wood saw - I'll verify the numbers BUT not sure how to get it across the country ????????????
- First Name: Austin
- Last Name: Farmer
Fastenall?
They won't go past Denver from Western Washington - the block (wife's actually) is cast date 10/26/13, Bill. If you can locate a shipper, I can get it to Fife or Tacoma, WA.
- First Name: DAN
- Last Name: MCEACHERN
Re: WTB 14 Block, Bill Everett
Steve- double check that. I thought the cut off line was the Mississippi River going east.
I just shipped some KRW combination machine parts to Utah - O.K. but they would not take the top base of it to Gene French in Colorado ?????
- Last Name: McClelland
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1911 Mother-n-law roadster, 1919 Coupe, 1920 Depothack, 1922 Centerdoor, 1923 Roadster, 1923 Speedster, 1924 TT Truck,
I have a 14 engine casting date is 11/6/14 it appears to be a replacement block Bill as there’s no engine number present, which is a good thing if you want to stamp your own number. Still has valves, cam, crankshaft, also has the transmission and for the best part I’m in Tennessee too.
About 30 miles north of Chattanooga, mile and a half from I-75.
Ph.423-2eight4-97fifty.
That casting date makes your an early 1915.
- Last Name: House
Not so fast Steve. Wayne Shelton stated on a few occasions here that the model transition between 1914 and 1915 lasted for many months. I believe him. He claimed to have seen era photos of Ts with a cowl and magneto lights but sporting 1914 style rear fenders. Also carbide headlamps with a 1915 windshield and curved rear fenders. Although 11 6 14 is not what the OP requested, I believe it could stand scrutiny as a bonafide 1914 engine.
- First Name: Joe
- Last Name: Kowalczyk
George, I 110% agree with Steve, it’s a 1915 engine.
Regards,
With all due respect, Wayne is a self-proclaimed expert.
I picked this engine up on a whelm while buying another T and never really looked at close so if it’s indeed a early 1915 that’s something I’ll keep, I have a early 1915 roadster, it has 4 rivet front fenders, fork mount mag bulb headlights someone else pointed out it’s a 5 panel body so with that said I may just tear it down and clean it up and keep with my T …. Thanks Guys for all your input I really appreciate it .
Thanks, Steve.
Thanks, Steve.
- First Name: Jonathan
- Last Name: Bodine
- * REQUIRED* Type and Year of Model Ts owned: 1914 roadster
Hello Bill:
I'm selling a 1914 engine elsewhere in the Classifieds. A new Scat crank and Stipe cam are also available if you or anybody else is interested.
Respectfully submitted,
Jonathan Bodine
Jonathan Bodine
- First Name: Rich
- Last Name: Jesteadt
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1913 Touring project w. "A" crank shaft
FYI I have a14 block with scoured clyinder wall.
- First Name: Chad
- Last Name: Azevedo
Believe it or not I also have an unstamped 14 block, you made me go out to check the cast date (7-24-14) on my block. Regardless of whether or not a replacement block was made it would have been made for a car older than the block. Therefore, a '14 or '15 replacement block would be as acceptable as new paint, upholstery, or more modern accessories in an earlier car say even an 11 02 12.
- First Name: T
- Last Name: Gates
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1926 Fordor
Here's a link to Fastenal's Blue Lane Freight branch with the map layed out with their boundaries. It's a bit tough to
sort out exactly as sadly they don't but it gives a pretty good idea!
https://www.fastenal.com/fast/blue-lane-freight#
- First Name: Mike
- Last Name: Leonard
- * REQUIRED* Type and Year of Model Ts owned: 6
ctleonard64@gmail.com located in mt.vernon Indiana
Have a cast date of 10/27/13. Came out of a running driving car. Sheared a couple of bolts, pictures of what I dug out! Still runs and hear no noises. Needs to be pulled apart. Has a starter on it. Have another hogs head if you don't want the starter, and a low head to go with.
You still with us, Bill ????????????
- First Name: Bill
Right here, Steve.
I don't use a smart phone or text - I'll get a couple photos for you - perhaps drop me an email through here then I'll be able to send them back.
- Last Name: Bodine
Bill Everett:
You might want to check out my ad just above this one of yours.
