Wanted, Bosch Magneto Plate
Mark Herdman
Topic author - Posts: 43
- Last Name: Herdman
Wanted, a Bosch Magneto setup that replaces the Generator.
Re: Bosch Magneto Plate
I believe I have one here in the States - I can get a weigh-in & you provide your postal code & I'll see what we can do.
Mark Herdman
Thanks Steve. I believe we corresponded many moons ago. My postcode is 4552 Queensland Australia.
Mark
Mark
Re: Wanted, Bosch Magneto Plate
For all of us, the postcode/zipcode plays no role in international shipping. Parcels from here to any destination in the USA are all at the same rate. Likewise, the reverse applies. Variations in charges within the USA are based on distance, so there are different rates charged. Australia Post now uses flat rates for parcels based on weight, so no difference for rates for longer distances. It would seem that after travelling all the way across the Pacific, the little bit extra to get to the final destination is of no consequence to either Postal system.
Mark Herdman
A good friend in USA who has helped me out for many years is also looking for one if anyone else has one for sale or just the rear cover plate and gear. Any help appreciated.
Mark
Mark
Mark Herdman
Thanks to Steve I have the Bosch Magneto drive fitted to the Rajo 8V now. Just like last raced in 1933.
babychadwick
- First Name: Chad
- Last Name: Azevedo
Interesting carbs, like a winfield H but not. Out of curiosity what are they?Mark Herdman wrote: ↑Tue Jun 24, 2025 4:40 amThanks to Steve I have the Bosch Magneto drive fitted to the Rajo 8V now. Just like last raced in 1933.
Mark Herdman
Solex side draft.
Looking good there, Mark !
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
"A good friend in USA who has helped me out for many years is also looking for one if anyone else has one for sale or just the rear cover plate and gear. Any help appreciated."
Mark- I have the gears for these in stock, just FYI.
Mark Herdman
The car its from 1927-28. You can see the Solex Carburettors and little aluminium air tubes in this photo. Still chasing at least 2 of these wire wheels.
Mark Herdman
Thanks Dan but Mike Bender helped him out via a friend of his.Dan McEachern wrote: ↑Tue Jun 24, 2025 8:05 pm"A good friend in USA who has helped me out for many years is also looking for one if anyone else has one for sale or just the rear cover plate and gear. Any help appreciated."
Michael Peternell
- First Name: Michael
- Last Name: Peternell
LoL! I wondered where that would end up!
Kevin Pharis
- Last Name: Pharis
One of those wheels popped up here on the forum a long while ago. Not sure if it could be found again…
Mark Herdman
Thanks Kevin. If you see anymore, please let me know. Just the centres would be good. They are the same both sides and fit a T hub perfectly. I do believe they were made to fit T fords and could have originated in the UK or Europe.Kevin Pharis wrote: ↑Wed Jun 25, 2025 11:16 pmOne of those wheels popped up here on the forum a long while ago. Not sure if it could be found again…
Mark Herdman
A better photo of the drive for the water pump. the sprocket on the cam gear is for an earlier version of the same motor driving a magneto on the right side of photo.
Kevin Pharis
- Last Name: Pharis
Your pics look familiar… no doubt you have posted them before. The centers look simple enough to duplicate, and good news is that you only need to make 2. Haven’t you always wanted to experiment with metal spinning…? Spokes and rims will be the easy partMark Herdman wrote: ↑Thu Jun 26, 2025 9:13 amThanks Kevin. If you see anymore, please let me know. Just the centres would be good. They are the same both sides and fit a T hub perfectly. I do believe they were made to fit T fords and could have originated in the UK or Europe.
Mark Herdman
Thanks for the update, Kevin. Be nice to find some wheel centres.
