Top Boot strap end cap
Topic author - Posts: 3913
I want to make a new top boot. I have the strap material, which is 5/8" wide as per original. I can't find the caps which are called C tips too. I used to be able to get them from Mark Cameron, but he must not have any more?
- Attachments
- boot strap 2.JPG (30.79 KiB) Viewed 1096 times
- First Name: Henry
- Last Name: Lee
Re: Top Boot strap end cap
Not hard to make Larry from "craft" channel sold at hobby supply stores. Just Sayin!
Look at saddle supplies too.
- First Name: Austin
- Last Name: Farmer
I wonder if any military reanacting sites could be of any help. Some of the old straps have similar clinched ends.
Good luck with your search.
"Military Web Strap End Tip, 5/8" Mil-Spec Webbing Ball Tip, Black. Lot of 20"
Ebay has these similar, same function.
Erik Johnson
- First Name: Erik
- Last Name: Johnson
In corset making that type of metal cap is called a boning tip.
Quarter inch and half inch metal caps are readily available - for example. Not sure about 5/8" caps.
1/4" tips
http://corsetmaking.com/boning-tips/CMS-SSB-BT4DZ.html
1/4" tips
http://www.voguefabricsstore.com/Spiral ... gross.html
1/2" tips
http://corsetmaking.com/boning-tips/CMS-SSB-BT2DZ.html
Google shopping boning tips
https://www.google.com/search?q=%22boni ... n&biw=1240& bih=686&tbm=shop&source=lnms&sa=X&ved=0ahUKEwiehKmGp7rKAhWBrYMKHfJDA74Q_AUIBigB& dpr=1#tbm=shop&q=boning+tips
Google images boning tips
https://www.google.com/search?q=boning+ ... 240&bih=68 6&tbm=isch&source=lnms&sa=X&ved=0ahUKEwj35--Yp7rKAhWlrYMKHSuYCMAQ_AUIlwEoAQ
1/4" tips
1/4" tips
1/2" tips
I am hoping someone may have a jar of these clips laying around? Maybe I'll luck out?
