WTB - Joe Morris crankshaft
blauvelt
Topic author - Posts: 264
- First Name: Douglas
- Last Name: Ogden
Curious if one is out there.
ModelTWoods
- First Name: Terry
- Last Name: Woods
Re: WTB - Joe Morris crankshaft
I'm curious who Joe Morris is, since no one has answered you.
Kevin Pharis
- Last Name: Pharis
Joe Morris made several T crankshafts (couple dozen?) back in the 70’s-80’s. They were fabricated from pins and webs, and meticulously pressed and welded together. Beautiful cranks, but unfortunately most have already broken. I know where some fragments are…
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
here you go.......
Mike Lebsack-Iowa
- First Name: Mike
- Last Name: Lebsack
- * REQUIRED* Type and Year of Model Ts owned: 11Torpedo, 11 Roadster, 13 Touring, 14 Roadster, 14 Touring
- Board Member Since: 2008
Dan, I think I have seen an engine with your main bearing caps and one of these cranks.
blauvelt
- Last Name: Ogden
I figured it was more of hunting for a piece of art and history than anything else. Wasn’t sure if any had survived.
Kevin Pharis wrote: ↑Fri Jul 11, 2025 11:26 pmJoe Morris made several T crankshafts (couple dozen?) back in the 70’s-80’s. They were fabricated from pins and webs, and meticulously pressed and welded together. Beautiful cranks, but unfortunately most have already broken. I know where some fragments are…
Dan McEachern
- First Name: DAN
Joe Morris was well known in HCCA circles for his knowledge and expertise of one and two cylinder Reo automobiles and rebuilding of the engines. The T cranks he made were because Joe had been fairly successful making Reo crankshafts in pieces and welding them together. Several of the T cranks failed because they were machined with a sharp corner in the fillet of the rear main thrust area rather than a generous radius. I'm not aware of any failures other than the rear flange issue, but perhaps someone else will chime in. AFAIK they were mostly made by Joe, but I understand a few were made by someone who worked with Joe after he stopped. Time wise these were made late '80s / early '90s.
blauvelt
- Last Name: Ogden
Thank you for sharing. It really seems that a lot of crank failures on rebuilt and even new cranks come down to not cutting enough radius in the crank journals.
Dan McEachern wrote: ↑Sat Jul 12, 2025 4:41 pmJoe Morris was well known in HCCA circles for his knowledge and expertise of one and two cylinder Reo automobiles and rebuilding of the engines. The T cranks he made were because Joe had been fairly successful making Reo crankshafts in pieces and welding them together. Several of the T cranks failed because they were machined with a sharp corner in the fillet of the rear main thrust area rather than a generous radius. I'm not aware of any failures other than the rear flange issue, but perhaps someone else will chime in. AFAIK they were mostly made by Joe, but I understand a few were made by someone who worked with Joe after he stopped. Time wise these were made late '80s / early '90s.
flatbroke3
- First Name: harold
- Last Name: musolf
- * REQUIRED* Type and Year of Model Ts owned: 1911 touring 1926 touring 1913 touring
- Board Member Since: 2010
deleted my post
blauvelt
- Last Name: Ogden
Was it a good one?
49willard
- First Name: Bill
- Last Name: Jones
- * REQUIRED* Type and Year of Model Ts owned: 1912 Foredoor
I had a Joe Morris crankshaft in my 1907 2 cylinder Buick. It failed after a number of miles when one journal rotated relative to the crankshaft throw.
Ujustwaite
- First Name: Brian
- Last Name: Waite
- * REQUIRED* Type and Year of Model Ts owned: B.H. Lawwell Special (1917-1921 Fairgrounds Racer)
I have one. I'll upload photos soon.
Dan McEachern
- First Name: DAN
"It failed after a number of miles ". The $$S solution for Buicks and Reo's was always a new billet crank from Molex or one of the other crankshaft companies, but ..............
Ujustwaite
- First Name: Brian
- Last Name: Waite
viewtopic.php?f=2&t=10178&p=361976&hili ... is#p361958
I forgot that I already posted the photos of mine here. Let me know if you would like more. I have it downstairs in the block but not installed in the car or bolted to an oil pan.
