NEW, Brassworks built Livingston SUPER-V radiator. For 1909-1916 Fords. Sitting on a chassis for mock up and has never been run.
Fantastic addition to any serious Speedster build.
No dings, dents, or scratches.
$3800
Located in Arnold Mo.
314-287-19 Zero One
SUPER-V Livingston Radiator *NEW*
Stephen1915
Topic author - Posts: 445
- First Name: Stephen
- Last Name: Noll
- * REQUIRED* Type and Year of Model Ts owned: 1916 Coupelet & 1911 Torpedo
- First Name: Henry
- Last Name: Lee
Re: SUPER-V Livingston Radiator *NEW*
Where’s the Livingston badge? That is where the value lays. Just Sayin
Stephen1915
- Last Name: Noll
Henry, the tag is $75 from Brassworks. It says “Brassworks Livingston Super V”.
I struggle to see what the additional value is in that.
This is interesting. I'm surprised to see the "usual" core when viewed from the backside. Does this radiator have essentially 3 cores? One on each side of the "vee" and the one "normal" core as well?
- First Name: Henry
- Last Name: Lee
That is an early true Livingston and the badge is an inverted triangle…., if you had the original badge, add an additional $5,000.00. The badge you are talking about is way after.
Again, just Sayin
Yes.., a 3 core triangle
Again, just Sayin
Stephen1915
- Last Name: Noll
New lower Price. $3800
