FS Headlamp Double Sockets 1915/16
MAG
Topic author - Posts: 488
- Last Name: Gember
- * REQUIRED* Type and Year of Model Ts owned: 1922 Touring 1926 Runabout 1926 Coupe 1929 Tudor
I have 4 headlamp sockets for 1915 or 1916 Model T’s. These differ from the later ones in that the pins are 90 degrees off. This was done to align the filament horizontally to allow the headlamp to be focused. Note the later socket in the middle of the picture. The focus screw for the 1915/16 is at the top of the light bulb, not to the side of the light bulb like the later ones. These are scarce. $25 each with $5 postage. Email me at markpaulagember AT aol DOT com
MAG
- Last Name: Gember
Re: FS Headlamp Double Sockets 1915/16
Sold 1 pair to Tad awaiting payment
MAG
- Last Name: Gember
Sold 1 pair, 2 are available
MAG
- Last Name: Gember
To the top
MAG
- Last Name: Gember
1 pair are still available
- Last Name: Hatch
Hard to find. In past I have brought whole headlights for the sockets. Too bad I don’t need any.
Erik Johnson
- First Name: Erik
- Last Name: Johnson
Those sockets are also correct for the 1917 model year (the focus adjustment screw on the headlight bucket is at the 12 o'clock position, just like 1915 and 1916).
While I agree that the 1915-16 Headlights with the adjusting screw at 12o'clock require a different socket as you have indicated. But it appears that the middle one, #3, in your photo is not one of the them. 1,2,4,5 look correctMAG wrote: ↑Mon Jul 28, 2025 6:35 pmI have 4 headlamp sockets for 1915 or 1916 Model T’s. These differ from the later ones in that the pins are 90 degrees off. This was done to align the filament horizontally to allow the headlamp to be focused. Note the later socket in the middle of the picture. The focus screw for the 1915/16 is at the top of the light bulb, not to the side of the light bulb like the later ones. These are scarce. $25 each with $5 postage. Email me at markpaulagember AT aol DOT com
For reference, most likely !
ewdysar
- First Name: Eric
- Last Name: D
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1915 Speedster #32, 1916 Touring, 1927 Runabout
Which is what the OP said the quoted section of your post...TRDxB2 wrote: ↑Thu Feb 12, 2026 12:20 pmWhile I agree that the 1915-16 Headlights with the adjusting screw at 12o'clock require a different socket as you have indicated. But it appears that the middle one, #3, in your photo is not one of the them. 1,2,4,5 look correctMAG wrote: ↑Mon Jul 28, 2025 6:35 pmI have 4 headlamp sockets for 1915 or 1916 Model T’s. These differ from the later ones in that the pins are 90 degrees off. This was done to align the filament horizontally to allow the headlamp to be focused. Note the later socket in the middle of the picture. The focus screw for the 1915/16 is at the top of the light bulb, not to the side of the light bulb like the later ones. These are scarce. $25 each with $5 postage. Email me at markpaulagember AT aol DOT com
Eric
MAG
- Last Name: Gember
The middle one was only shown in the picture to show the difference between the early and late double socket orientation.
