WTB-Burns Oil Intake Manifold
WorldChamp1914
Topic author - Posts: 404
- First Name: Gary
- Last Name: Hagen
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring and a 1921 Sightseeing Bus.See SF On a Dime
I have never seen one before
Re: WTB-Burns Oil Intake Manifold
More info at this link https://www.mtfca.com/discus/messages/80257/117585.html
Link?
I "think" they used a special carburetor to burn kerosene and the double-back exhaust was used to heat the kerosene (or other fuel oil?) such that it would burn better in the engine.
I have seen one similar to that before.
WorldChamp1914
- First Name: Gary
- Last Name: Hagen
Thank you!
I added the think to my first entry above. Started reading through it and its likely set up up to burn kerosene. The discussion include the addressWayne Sheldon wrote: ↑Thu Jul 31, 2025 5:25 amLink?
Jay - In Northern Ca. on Saturday, December 19, 2009 - 09:28 pm:
"Well it took me a while but I dug around and found the original crate for the manifold. The branding iron lettering on the crate reads.
FROM, THE BURN-OIL DEVICE CO., MANUFACTURERS OF, BURN-OIL KEROSENE ATTACHMENTS, FOR FORDS, 120 N. JEFFERSON AVE., PEORIA, ILL."
That got me interested as Peoria is about 80 minutes from here, also where PACO bodies where made
I believe you could use a regular carburetor with that for kerosene and maybe for diesel and some light crude oils. You'd need to start on gasoline, and an air intake heat device would be helpful, especially in cold weather. Today's "white" kerosene would probably work very well with that set-up... if you could afford it. I'd think you'd need to change the oil very frequently and probably clean the plugs daily. Hot plugs might help, but dieseling could become a problem. Modern detergent crankcase oil might help prevent rings sticking from heavy carbon, and running the engine around 200 F would also help. If only kerosene was still 6 cents a gallon...
DustySpokes
- First Name: Edmund
- Last Name: Niedzielski
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1922 Mercury Bodied Speedster, 1926-27 Roadsters /Tourings
Hi Gary, I am pretty sure that I have one of these in my collection. I would sell it to you Amigo . -Dusty
