I finally found the missing links for a Corbin speedo set for my Tourer, and can let go of the Stewart stuff I have accumulated in the meantime.
The model 160 speedo is a restored Russ Furstnow purchase, nice. The 60" cable is undamaged . The inner cable turns freely, but probably should be removed, cleaned and re lubricated.
The no.1959 swivel has been dismantled, cleaned, inspected and lubricated ready for use. It is in top condition.
The number 11077 wheel gear for 30" wheels has been abrasive blasted and primed. It comes with the mounting screws and spacers.
The mounting clamp is there. All you need to purchase from the vendors is the extended spindle arm nut.
$800 including expensive tracked postage to your door. PayPal payment preferred.
Stewart speedo set-up.
Topic author - Posts: 6743
Re: Stewart speedo set-up.
To the top please.
