spare tire clamp Sold
Topic author - Posts: 1718
- First Name: Melba
- Last Name: Nolan
- * REQUIRED* Type and Year of Model Ts owned: 23 roadster
For sale: spare tire rim clamp $10 plus postage
- First Name: Keith
- Last Name: Townsend
Re: spare tire clamp
I'll take it.
Do you have the bolts for it?
Keith
Keith
There are no bolts.
The big hole goes over the existing carrier stud.
The upper hole & notch are for a padlock.
- First Name: Keith
Mine has no stud, just a square hole, about 7/16".
There should be a demount able sized fine thread stud swedged from behind.
You'll need to make & secure that stud.
- First Name: Keith
My thought was to fabricate one out of a lug bolt.
That can work. Might want to weld/braze into position.
- First Name: Keith
I just painted it...
- First Name: Jack
- Last Name: Putnam
Once it is in place. Held by the nut it won't fall out. No need to braze.
Until you remove the spare rim.Jack Putnam, in Ohio wrote: ↑Wed Aug 13, 2025 4:36 pmOnce it is in place. Held by the nut it won't fall out. No need to braze.
Quiescently, I saw a nos replacement carrier base mount last night.
The stud is a fine threaded carriage bolt.
The outer edges of the square of the carriage bolt are chiseled down to lock the square under the bolt head in place.
- First Name: Keith
