FS Ruckstell housing and parts
KimDobbins
Topic author - Posts: 1683
- First Name: Kim
- Last Name: Dobbins
Ruckstell housing plus other half. The tube is bent, can be straightened with a press or an extra tube is included. $135.00. P202 diff assembly, $125. P146 sliding gear, $60. P211 bearing $35. P147 notch plate, $50. P144 sun gear, $40. P93 internal ring gear, new, $200, used $100. P87 pinion gears (2) $25 each. All plus shipping. kdmks AT att.net. All parts are used except for 1 internal ring gear.
KimDobbins
- First Name: Kim
KimDobbins
- First Name: Kim
Re: FS Ruckstell housing and parts
Housing and parts are still available.
KimDobbins
- First Name: Kim
The following parts have been sold.
p211 bearing
p144 sun gear
p93 internal ring gear used
p87 pinion gears
p211 bearing
p144 sun gear
p87 pinion gears
hamish
- First Name: Hamish
- Last Name: McDonald
- * REQUIRED* Type and Year of Model Ts owned: 1913, 1915, 1920
Still available, and how expensive is it going to be to post to Australia?
Hamish, you might want to say which parts you are interested in.
KimDobbins
- First Name: Kim
Hamish, I'll let you know Monday which parts are still available.
KimDobbins
- First Name: Kim
