Crank shaft pulley
Topic author - Posts: 49
- First Name: Patrick
- Last Name: Ainslie
- * REQUIRED* Type and Year of Model Ts owned: 1911 & 1919
Crank shaft pulley
WTB Texas T/Birdhaven aluminum crank shaft pulley. They used to sell an aluminum pulley that had grooves in the rear part of the pulley to drive an alternator and flat on the front to drive the fan. I could use 2 if possible. Thanks. Pat
Re: Crank shaft pulley
To the top
- Last Name: Juhl
I take it your car is a non-generator car. Most of the setups I've seen mount the alternator on the driver's side and use one longer belt. I don't know if that would be practical for your situation but you might consider it.
I have the alternator on the drivers side. I am using 2 belts. One with 4 grooves to the alternator with a grooved pulley and a second to the fan with a wide flat belt. That is why I need to have this type of pulley. The one I used became unusable and need to replace it
