WINFIELD MODEL S CARBURETOR
Roadsterguy
Topic author - Posts: 17
- First Name: Rene
- Last Name: Gonzalez
- * REQUIRED* Type and Year of Model Ts owned: 1927 tudor
Rebuilt Winfield model S-AA-D. DOWNDRAFT. New gasket kit installed. Intermediate and high speed compensators are correct and stamped AA. All passages were thoroughly cleaned and carb was ultrasonic cleaned before reassembly. Nos choke cable clamp and linkage arm installed on correct choke horn stamped S-41-B. Throttle is smooth. AA winfield carbs flow about the same cfm as a 81 stromberg so its good little upgrade if your running a banger engine. Comes with an original (not copy) of the installation instructions and extra set if gaskets. $1000 shipped to your door. Located in La Mirada Ca
ewdysar
- First Name: Eric
- Last Name: D
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1915 Speedster #32, 1916 Touring, 1927 Runabout
Re: WINFIELD MODEL S CARBURETOR
email sent
Roadsterguy
- First Name: Rene
WINFIELD IS STILL AVAILABLE.
