New US-Made Rims and Wheels
Topic author - Posts: 2285
- Last Name: Juhl
Some months ago Steve Jelf mentioned that he'd heard of a company in Florida that made wheels for classic cars. I tracked them down and learned that the owner, Rodrigo Diaz, was in the process of developing demountable, non-demountable and split-rims for Model T's. I offered my help and encouragement and thru this process we became friends. I've shared some info about the Model T hobby with him and tested a couple of his prototypes on my 1917 Touring. I'm impressed by the quality of his products and can recommend them without hesitation. I have absolutely no financial interest in his company. My interest lies in promoting the Model T hobby. There's a lot more to the story but rather than make this post uncomfortably long I have put together a informative pdf which I've attached.
I realize that by recommending a commercial business I may be crossing a line but I feel it important to get the word out. I previously spent hundreds of dollars importing a pair of rims from Australia that turned out to be totally useless so having a quality source of US-made rims can only help the hobby.
- First Name: Marc
- Last Name: Engel
- * REQUIRED* Type and Year of Model Ts owned: 1915 Pick Up
Re: New US-Made Rims and Wheels
Those split rims look awesome!
- Last Name: Hatch
Do you know if and where they will be set up at Hershey?
Thanks for posting this. Dan
I'll bet these people would know...
New Wheels and Rims for Model T’s
Made in the USA by INDAZ AMERICA
Rodrigo Diaz, CEO
495 S. Shell Road, Ste A6, Debary
Florida, 32713
<www.indazamerica.com>
mailto:<info@indazamerica.com>
(689) 275-6734
- Last Name: Juhl
When I spoke with Rodrigo a week ago he said he hadn't received a site number yet. He's going to let me know and I will post it. He and his daughter are planning to attend and bring a selection of their wheels and rims.
- Last Name: Juhl
I just heard from Rodrigo at INDAZ-USA. He will be in space OAF43 at Hershey.
- Last Name: Arms
- * REQUIRED* Type and Year of Model Ts owned: 1912 Touring
Any idea how much they are charging for the rims?
- Last Name: Hatch
Thanks for space numbers. If I can get loose from my spaces for one day I will try and go look at them. Dan
- Last Name: Juhl
You can buy used rims for around $100 but they are often corroded (especially on the inside) and may have sharp edges on the "clincher" that have been known to cut tires. You can file the edges down but then you have less holding the tire. The main problem is that good original rims are getting harder to find, at least in my experience. Considering the uncertainty of the steel supply and generally higher prices across the board, I think Rodrigo's prices are reasonable. Remember, Model T rims are a small market and are not mass produced. Rodrigo makes each rim or wheel individually and each requires several steps in the fabrication process and specialized tooling. For me, I'm glad that quality new rims are available. I have some less than perfect rims that I am replacing with his new ones. After all, wheels are kinda important aren't they?
- First Name: T
- Last Name: Gates
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1926 Fordor
Yep, I need one and will be ordering it soon.Oldav8tor wrote: ↑Sat Sep 06, 2025 9:37 pmYou can buy used rims for around $100 but they are often corroded (especially on the inside) and may have sharp edges on the "clincher" that have been known to cut tires. You can file the edges down but then you have less holding the tire. The main problem is that good original rims are getting harder to find, at least in my experience. Considering the uncertainty of the steel supply and generally higher prices across the board, I think Rodrigo's prices are reasonable. Remember, Model T rims are a small market and are not mass produced. Rodrigo makes each rim or wheel individually and each requires several steps in the fabrication process and specialized tooling. For me, I'm glad that quality new rims are available. I have some less than perfect rims that I am replacing with his new ones. After all, wheels are kinda important aren't they?
- Last Name: Juhl
Reminder-If you want to pick up your rims at Hershey you need to get your order in by 9/15
