Found what I was looking for - WTB - bracket that mounts on front frame crossmember
milkman
First Name: Lee
Last Name: Kilmer
Post by milkman » Sat Sep 06, 2025 4:14 pm
I am in need of the bracket and mounting u-bolts that goes on front frame cross member and holds the front springs in place as well as supports the nose of the engine pan on a '27 touring.
Mike Silbert
Last Name: Silbert
Re: WTB - bracket that mounts on front frame crossmember
Post by Mike Silbert » Sat Sep 06, 2025 5:22 pm
If this is for the stated '27 Touring then the front mount is the late style with two built in studs.
The dual loose u bolt style was discontinued many years before.
Verify what you are looking for, both styles are out there.
Mike
Post by TRDxB2 » Sat Sep 06, 2025 6:07 pm
I have all 3 styles of the front engine mount/spring clip. Some painted others surface rustThe 25' 27' had a hole for a bolt. These are some that I had sold. I'll need to get a picture of what you need.
This the '26 -27' style
This the '2 to '25 style
This is the earlier style
Post by Allan » Sat Sep 06, 2025 9:50 pm
The first photo shows the correct mounting for a 1927 model T. the threaded hole in the front accepts a bolt which fastens the radiator apron in place.
