Found what I was looking for - WTB - bracket that mounts on front frame crossmember
Topic author - Posts: 7
- First Name: Lee
- Last Name: Kilmer
I am in need of the bracket and mounting u-bolts that goes on front frame cross member and holds the front springs in place as well as supports the nose of the engine pan on a '27 touring.
- First Name: Mike
- Last Name: Silbert
Re: WTB - bracket that mounts on front frame crossmember
If this is for the stated '27 Touring then the front mount is the late style with two built in studs.
The dual loose u bolt style was discontinued many years before.
Verify what you are looking for, both styles are out there.
Mike
Mike
I have all 3 styles of the front engine mount/spring clip. Some painted others surface rustThe 25' 27' had a hole for a bolt. These are some that I had sold. I'll need to get a picture of what you need.
This the '26 -27' style
This the '2 to '25 style
This is the earlier style
The first photo shows the correct mounting for a 1927 model T. the threaded hole in the front accepts a bolt which fastens the radiator apron in place.
