Wanted Delco 5195 Two Cap Distributor
Topic author - Posts: 397
- First Name: Chris
- Last Name: Haynes
- * REQUIRED* Type and Year of Model Ts owned: 1921 Runabout
I am searching for a Delco 5195 Two Cap Distributor. Originally used on four cylinder Stutz and other makes.
- First Name: Ed
- Last Name: Martin
- Last Name: Nunn
Re: Wanted Delco 5195 Two Cap Distributor
Have you checked with Tom VanMeeteren? He's a forum member who might have what you need.
- First Name: JOHN
- Last Name: RENDEMONTI
- * REQUIRED* Type and Year of Model Ts owned: 1925 two door sedan
You do not need one. The mount on the engine is for a standard magneto.
John
John
- First Name: Chris
- Last Name: Haynes
My head is a dual plug head.
- First Name: Tom
- Last Name: Magee
- * REQUIRED* Type and Year of Model Ts owned: 1924 Speedster
Chris, check out what Tim Dickson has to offer. Here is his website: https://www.dicksonautomotiverestoration.com
At one point Tim offered a dual distributor unit but I am not seeing it on his website, maybe they are still available. Tim also sells a dual spark, single distributor that is made with modern, easy to find components.
I bought the Delco dual distributor from John Karvaly but it is not for sale.
Tom
Tom
