Metal ring that fits in wood felloe valve stem hole?
Last Name: Hjortnaes
Post by DHort » Fri Sep 26, 2025 3:47 pm
Does anyone know if Stutzman puts the ring in the valve stem hole or do you need to purchase it somewhere?
This is for a wood felloe.
CALLEN1234
First Name: Charlie
Last Name: Allen
Re: Metal ring that fits in wood felloe valve stem hole?
Post by CALLEN1234 » Fri Sep 26, 2025 4:27 pm
Stutzman installed the ring in my wheels.
BigAl
First Name: Alan
Last Name: Stein
* REQUIRED* Type and Year of Model Ts owned: 1911 Touring (August 1911)
Post by BigAl » Fri Sep 26, 2025 9:34 pm
Stutzman does exceptional work. When you get them back they are perfect and all you need to do is paint them. Only suggestion is if you want the stamped joint plates which denote the wheel manufacturer you need to supply them because he uses blank ones. Great guy to work with.
Post by DHort » Sat Sep 27, 2025 11:49 am
Alan
That was my next question. I pulled off my old plates and was going to paint them.
Post by DHort » Sat Sep 27, 2025 11:51 am
I am wondering if he has to heat up the rims to install them or can I paint them before I deliver them to Noah? Does he just press them on?
Post by speedytinc » Sat Sep 27, 2025 11:58 am
I have seen new wheels that had the tubes made from copper tubing. (Stutzman?)
Ask him directly.
Jones in Aiken SC
First Name: Gregory
Last Name: Jones
Post by Jones in Aiken SC » Sat Sep 27, 2025 4:13 pm
Stutzman fabricated them and installed them in the wheels he did for my 1912 Roadster.
CALLEN1234
First Name: Charlie
Last Name: Allen
Post by CALLEN1234 » Sun Sep 28, 2025 11:01 am
The hubs and rims that I took to Stutzman were painted.
