WTB Upper hose to Head Water Pump
jmemjr
Last Name: Memmelaar
* REQUIRED* Type and Year of Model Ts owned: 1912, 1914, 1915
Post by jmemjr » Thu Oct 23, 2025 8:52 pm
I believe that I have seen a water pump that is in between the upper hose to the cylinder head for a Model T. This is a speciality build and it will need a water pump. The standard location for it is out as there is no more room on that side of the engine.
It is driven from the fan belt and I thought I found one at Hershey but it's not correct.
TIA
John
Last Name: Gregush
Re: WTB Upper hose to Head Water Pump
Post by Mark Gregush » Thu Oct 23, 2025 9:13 pm
Nims is one brand. Think off the top of my head they were made in Stockton California.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Thu Oct 23, 2025 10:10 pm
Hope you don’t need much of a “pump”, the Nims type pumps are almost novelty. How are you getting water into the block…? If you have room for the original water pipe and inlet, there are several pumps where the pump housing is at the front, rather than the typical Texas T style at the water inlet passage. Here is a Boyd pump
Post by TRDxB2 » Fri Oct 24, 2025 12:51 am
TIA
John
Here is some info on the NIMS .....
Post by TRDxB2 » Fri Oct 24, 2025 12:59 am
There is another style on eBay for sale $275 https://www.ebay.com/itm/226455591620?c ... VrBqrPxqbg
jmemjr
Post by jmemjr » Fri Oct 24, 2025 6:41 am
Got the one on E-bay! thank you everyone!
