WTB: Stipe High Lift Camshaft
frontyboy
First Name: dick
Last Name: dock
* REQUIRED* Type and Year of Model Ts owned: T sprint cars
Post by frontyboy » Sat Oct 25, 2025 11:26 pm
Would like to buy a hi lift Stipe cam new or used.
thnx
frontyboy
Bill Anziani
First Name: Bill
Last Name: Anziani
Re: WTB: Stipe High Lift Camshaft
Post by Bill Anziani » Sun Oct 26, 2025 4:26 pm
I believe Kevin Pruis sells them or something very similar
Mike Penserini
Last Name: Penserini
* REQUIRED* Type and Year of Model Ts owned: 27 roadster pickup, brass speedster, Mercury # 253 B, Mercury # 1070, Faultless "Hoosier" parts collection.
Post by Mike Penserini » Tue Oct 28, 2025 4:51 pm
Yes, Kevin Pruis is selling a Model T per
formance cam.
blauvelt
First Name: Douglas
Last Name: Ogden
Post by blauvelt » Wed Oct 29, 2025 9:52 am
3 degrees exhaust overlap?
ewdysar
First Name: Eric
Last Name: D
Post by ewdysar » Wed Oct 29, 2025 1:00 pm
Nope. Here is the same info in a more readable table format, from the "Model T Cam Project" on the Model T Ford Club of Tulsa webpage.
https://mtfctulsa.com/Cams/design_280.html
Keep crankin',
Eric
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Wed Oct 29, 2025 2:57 pm
There is s slight typo in Kevin's timing tag that makes the timing events a little hard to read and might be somewhat confusing:
The red circled line should probably not be there for the intake timing event:
a minor point, but..............
Cam Timing.JPG (25.78 KiB) Viewed 619 times
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Wed Oct 29, 2025 5:03 pm
Needs to remove the line after 54 and change ABCD to ABDC…
And 10 needs to be changed from ATDC TO BTDC…
ewdysar
First Name: Eric
Last Name: D
Post by ewdysar » Wed Oct 29, 2025 5:16 pm
While the 10 related to the intake opening looks to be BTDC in the data graphic, you can see in the specs that the intake opening is indeed 10 ATDC, the image is wrong for this cam. But I believe that the blank format graphic for these figures is more commonly used for cams in modern, higher speed engines that do have exhaust overlap with the intake opening BTDC and the exhaust closing ATDC. The figures added to the graphic for this cam do match the .280 lift cam data provided above, even though the graphic doesn't quite fit.
Keep crankin',
Eric
frontyboy
First Name: dick
Last Name: dock
Post by frontyboy » Thu Oct 30, 2025 12:24 am
How much? still available?
frontyboy
Dan McEachern
First Name: DAN
Post by Dan McEachern » Thu Oct 30, 2025 1:31 am
Allen is correct on the ABDC. Eric is correct on the ATDC valve event. Kevin does have cams available. Best to contact him at the above #.
ewdysar
First Name: Eric
Last Name: D
Post by ewdysar » Thu Oct 30, 2025 1:34 am
frontyboy
You can contact Kevin Prus directly from the forum, his user id is racer_22. As of Hershey’s earlier this month, he had plenty.
Eric
Etudes10
First Name: Greg
Last Name: Cosner
* REQUIRED* Type and Year of Model Ts owned: 1915 touring, 23 coupe, 26 speedster, 25 tudor, 25 TT
Post by Etudes10 » Thu Oct 30, 2025 12:44 pm
https://ebay.us/m/17Myws
Listed on ebay.
