I ran across these that an old friend had & his widow would like to sell them They are RM bands & hardware with flame cut mounts & improvised equalizer for what appears to be large drum brake setup there are no drums but the rest seems to be there. Everything appears to be new. If
anyone knows more about them we would like to know. I would think they should be worth at least $500
the rods are there also.
Looks like USPS will ship for under $50
F/S RM ? Large drum brake set up
Topic author - Posts: 2014
- First Name: craig
- Last Name: leach
Re: F/S RM ? brake set up
Seeing how the 2 rear mounting tabs utilize small bolts, it's most likely a set for a large drum set up - one has to drill out those 2 rivets from the large drum backing plate.
- First Name: craig
- Last Name: leach
Good observation Steve I was going by the diameter which is hard to do without a drum.
Small drum brake rear spring bars both attach to the rear brake anchor bolt.
- First Name: craig
- Last Name: leach
Please move to top. Thanks
- First Name: craig
- Last Name: leach
Re: F/S RM ? Large drum brake set up
Lets try this one more time before I return them to the owner.
