FS: Imperial Manifold Primer
Topic author - Posts: 6587
The manifold is in excellent condition, the ports look unused. The plunger spring takes more effort than first expected but it needs to cause the short burst of fuel. The green tap is preventing a new ferrule from sliding off. Have everything else per the parts list except the supply elbow and 3/8 supply line. These parts, from the plunger to your fuel line, would need to be adapted to your carburetor feed setup anyway. T I will print off the instructions .
$150 plus shipping. Prefer PayPal to friend/family but will accept a personal check. If interested email me via the Forum
Re: FS: Imperial Manifold Primer
Instructions..............
The diagram shows several check valves for siphon and squirt -
jump....jump.... bump....
Shannon_in_Texas
- First Name: Shannon
- Last Name: Helm
Frank, shouldn't that be pump....pump....bump (the starter)?!?
pump..pump..pump.
Santa says buy it its the last one
- Attachments
- santa.png (238.16 KiB) Viewed 510 times
South Park Zephyr
- Last Name: Francis
- * REQUIRED* Type and Year of Model Ts owned: 25 RPU, 27 Roadster
- Board Member Since: 2022
Frank I will take it
Scott
636-544-775zero
Scott
636-544-775zero
Its yours. Will text/email you total later Today.
