FS LARGE DRUM ROCKY MOUNTAIN BRAKE SET (SOLD)
Mark Chaffin
Topic author - Posts: 4847
- Last Name: Chaffin
One pair of Rocky Mountain Brakes. Linings look pretty good. Price WAS $450 NOW $400 plus actual shipping. Mark Chaffin (951)805-0928
Re: FS LARGE DRUM ROCKY MOUNTAIN BRAKE SET
Those are Jack Sunderlin reproductions.
big2bird
- First Name: Jeffrey
- Last Name: Hausey
I was thinking that as well.
Still clearly a deal.
Mark Chaffin
Please elaborate. Would be nice to know what to look for in the future.
big2bird
- Last Name: Hausey
Post a picture where the fixed post is on the end. Originals have adjustment, Jacks were fixed.
big2bird
- Last Name: Hausey
Cam adjusts for drum in or out. On Jack's, you shim the bracket in or out.
Mark Chaffin
Good to know. Thank you Jeff.
Jack didn't put those cams on, because he didn't know what the purpose of them is!
Chris Instness
- First Name: Christopher
- Last Name: Instness
- * REQUIRED* Type and Year of Model Ts owned: 1915 runabout, T speedster
Does anyone have a set of drums for these? Do they use the 11 3/4” pressed steel drum or would this set have come with cast drums?
If these are for large stock drum, 11-1/4in, on the 1926-27. The 1909-1925 small drums need the larger outer drums (11-3/4" diameter) that are used in conjunction with original stock drum.Chris Instness wrote: ↑Sat Dec 13, 2025 1:21 pmDoes anyone have a set of drums for these? Do they use the 11 3/4” pressed steel drum or would this set have come with cast drums?
Are you sure about that?? Looks like the bracket attaches @ the small drum brake shoe bolt.
big2bird
- Last Name: Hausey
Jack only made small drum RM. For 26-27 he made the AC units.
They used cast iron drums.
Mark Chaffin
According to the "sperts", these brakes are older reproduction brakes that require drums. As such, price has been reduced. Thanks all for your input.
Re: FS LARGE DRUM ROCKY MOUNTAIN BRAKE SET (REDUCED)
Well worth the price. These brakes will lock the rear wheels forward & reverse!
Get a set of Bud Williams drums & you 're golden.
I am surprised they haven't sold yet. If I didnt already have a spare set, they'd be mine.
Mark Chaffin
Going to Drew. Thanks all.
