FS 23” TT Rear Wheels and Rims SOLD
Tparts
Topic author - Posts: 403
- First Name: Don
- Last Name: Lang
- * REQUIRED* Type and Year of Model Ts owned: Multiple years
Barn Find pair of 23” Ton Truck Wheels and Rims. SOLD plus shipping or free delivery to Luray Va Swap Meet in May.
Lang’s 1-800-872-7871
James
- Last Name: McFall
- * REQUIRED* Type and Year of Model Ts owned: 1925-ish T
Re: FS 23” TT Rear Wheels and Rims $500.00
Well, I guess I've saved up enough money to start buying stuff again! These will fit the Ruckstell axles?
Mike Silbert
- First Name: Mike
- Last Name: Silbert
The Ruckstell axle assemblies use the stock axles for their setup.
BUT... The car axles (and its rear wheels) and the TT truck axles (and its rear wheels) are different.
Wheel hubs, hub caps, spokes, brakes, felloes, rims, tires, etc are different between the TT truck and the cars.
And the TT trucks used different wheels front and back making the rear truck wheels hard to find.
Your profile says "1923 T truck conversion"
Check to make sure what wheels you need on your conversion truck, sometimes they are not even Ford parts.
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Pretty sure TT front wheels are same as passenger car. Could be mistaken but............what is different?
Nothing - same front wheels.
James
- Last Name: McFall
The problem I have is the thing is more a collection of parts than anything else. Which makes getting parts annoying to say the least. I do have a pair of hubs that fit, and a few different front wheels I've collected. From what I can tell, it is a ton truck rear end because of the large axles.Mike Silbert wrote: ↑Tue Dec 16, 2025 11:37 amThe Ruckstell axle assemblies use the stock axles for their setup.
To be 100% post a photo of the rearend in question.
Mike Silbert
- First Name: Mike
In spite of my attempt to be as clear and accurate as possible, what I wrote could be misleading.
What I wrote
"And the TT trucks used different wheels front and back making the rear truck wheels hard to find."
Should read
"And the TT trucks used different wheels front and back on the same truck, making the rear truck wheels hard to find.
The front wheels on a TT truck are the same as the front wheels on the cars"
Pictures of the rear axle can help a lot identifying parts.
Sorry if I caused undue confusion
Mike
Should read
Mike
James
- Last Name: McFall
No problem. All these different sizes confuse me anyway. I talked to them about the wheels. Waiting to hear back on the shipping cost.Mike Silbert wrote: ↑Tue Dec 16, 2025 3:20 pmIn spite of my attempt to be as clear and accurate as possible, what I wrote could be misleading.
Should read
Mike
slang250
- Last Name: Lang
- * REQUIRED* Type and Year of Model Ts owned: 1912 touring, 1926 speedster, 1926 TT
Wheels have been sold to James,
Thank You
Thank You
