model T mainbearing mold
Gene_French
Topic author - Posts: 1099
- First Name: Gene
- Last Name: French
- Board Member Since: 2014
my original design Model T mainbearing mold will pour the babbitt bearings in BOTH the block and caps of the Model T Ford engine ... the bearings will be poured at 1 1/8" diameter to allow for finish machining as needed ... instructions are included as well as my phone or email support ... price is $125 plus $19.30 priority mail postage in lower 48 states ...actual postage outside this area or INTERNATIONAL ...Gene french ph. 970-581-2808 address : Gene French 49519 cr23 Nunn, Co. 80648
Gene_French
- First Name: Gene
- Last Name: French
Re: model T mainbearing mold
picture of babbitted block and caps ... my design mainbearing mold uses a single center gate (spru) ... the intent in this design is to eliminate the knit line that can occur with many of the vintage multiple gate molds ... the multiple flow front that was present with the multiple gate tools often entrapped gasses or impurities at the knit line ... the single center gate design will cause gasses or impurities to move toward the vented endcaps to avoid entrapment ...always an optimist Gene French
Gene_French
- First Name: Gene
- Last Name: French
to the top again ...thanks MTFCA
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
to the top again ....thanks MTFCA
Gene_French
- First Name: Gene
- Last Name: French
BarrettR
- First Name: RogerA
- Last Name: Barrett
Had some issues with the babbit not flowing all the way to the top of the mold especially the right front corner ect. Would you suggest putting shims under the mold plate? Or inlarging the vent holes?
- Last Name: Tannehill
- Board Member Since: 2002
Your mold is not hot enough.
Gene_French
- First Name: Gene
- Last Name: French
exactly right Brother John ... a uniform pre-heat is very important ...
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
to the top again...thanks MTFCA
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
to the top again ... thanks MTFCA
Gene_French
- First Name: Gene
- Last Name: French
to the top again , thanks MTFCA
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
will have molds and instructions on display at the Duncan,Ok. swapmeet in March ... stop in and visit and pickup tools to save on postage ...Gene French 970-581-2808 or gfrench1953@hotmail.com
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
