FS cowl gas tank
Karl Von Neumann
First Name: Karl
Last Name: VonNeumann
Board Member Since: 2022
FS cowl gas tank
Post by Karl Von Neumann » Thu Dec 11, 2025 9:24 am
Cowl gas tank does not leak solder has been touched up round the outlet. Over flow tube is broken off at the outlet Decent looking usable tank $200 plus the ride or local pick up pleasant prairie wisconsin can sell you the straps for an additional 50$
Karl Von Neumann
First Name: Karl
Re: FS cowl gas tank
Post by Karl Von Neumann » Thu Dec 18, 2025 12:09 pm
Move to top
Karl Von Neumann
First Name: Karl
Post by Karl Von Neumann » Wed Jan 14, 2026 10:04 am
Move to top
schwabd1
First Name: David
Last Name: Schwab
Post by schwabd1 » Thu Jan 15, 2026 10:28 pm
Is this an open car or closed car tank?
Karl Von Neumann
First Name: Karl
Post by Karl Von Neumann » Fri Jan 16, 2026 11:36 am
26 27 is all the same goes under the cowl
Post by TXGOAT2 » Fri Jan 16, 2026 11:41 am
Isn't the four door closed car tank on the 26-27 under the seat?
Karl Von Neumann
First Name: Karl
Post by Karl Von Neumann » Fri Jan 16, 2026 11:45 am
Yes! I was just thinking about that the 4 door is under the seat thebrest are cowl mount
