Beginning Top Left: TT C Cab front and rear corner brackets (2) + 1 curtain frame bracket.$25 Accy cast or forged crankcase ‘ears’ Pat’d April 1918 Zoom In! $40, Pair pan/hogshead/block brackets.$35 Really nice NH Straight Thru Carb and manifold. Removed it and replaced with a U&J Only $350, Powder coated ‘17-‘23 sheet metal radiator lower apron $35, Really nice original ‘26-‘27 steering column cab sheet metal.$25 Pair of early front fender/headlamp brackets for use w/ acetylene lamps (only 1 displayed).$75 Really nice Ford crankcase ‘ear’ $10, brass top coil piece $9, brass sediment bulb connection $5, Holley 3 screw carb top (iron) $9 (zoom in), Early spindle arm $20, pair real nice spring perches.$65 3 early automotive socket tools $30..All + cheapest shipping
gwhouse731(at)gmail(dot)com
FS: Table Load Model T Goodies
Topic author - Posts: 3017
- Last Name: House
- Last Name: House
Re: FS: Table Load Model T Goodies
Charlie_26_TT_Ccab
- First Name: Charlie
- Last Name: Coleman
- * REQUIRED* Type and Year of Model Ts owned: 1926 TT C Cab Stakebed Truck
Sent you an email.
- Last Name: Humble
Email sent.
- Last Name: House
TT corner brackets and pr cast crankcase ‘ears’ spoken for and all boxed up. Thanks Charlie and MTFCA
