F/S 16-20 fan Sold thanks MTFCA
Craig Leach
First Name: craig
Last Name: leach
Post by Craig Leach » Mon Nov 03, 2025 9:36 pm
16-20 steel fan hub, good barrel for belt tight rivets, bushings a little loose but serviceable. $55 + shipping.
Craig.
Karl Von Neumann
First Name: Karl
Last Name: VonNeumann
Board Member Since: 2022
Re: F/S 09-16 fan
Post by Karl Von Neumann » Tue Nov 04, 2025 11:02 am
Fan hub for 09 to 16 was brass steel is 16 and on
Craig Leach
First Name: craig
Last Name: leach
Re: F/S 16-20 fan
Post by Craig Leach » Tue Nov 04, 2025 11:40 am
You are correct Karl I just looked @ the blades in the parts books. Thanks for the correction.
Craig.
Re: F/S 16-20 fan
Post by Allan » Tue Nov 04, 2025 4:40 pm
Those fan blades differ from our Canadian sourced parts. On ours, the outer end of the embossed ridge tapers out to almost nothing. Those are quite definitely sharply defined at each end, more like the deeper pressings on the very early blades. Interesting! Nice example.
Craig Leach
First Name: craig
Last Name: leach
Re: F/S 16-20 fan Lower price
Post by Craig Leach » Mon Jan 26, 2026 8:56 am
Now $40 + shipping
