Set of Four matched set forged model A rods $350
Standard rod bearing set $150
New diamond pistons 0.060 $125
Piston Ring set $45
Buy it all for $650 + shipping if needed, located 20 minutes SW of Port Huron, Michigan
FS Model A Insert Connecting Rods / Pistons / Rings
SMHnat
Topic author - Posts: 59
- First Name: Seamus
- Last Name: Hnat
- * REQUIRED* Type and Year of Model Ts owned: 1914 Ford T Touring
Seamus Hnat
Antique & Collector Car Specialist
Ford Ts As & V8 Cars
Specializing in Precision Tuning & Carburetion & Ignition Systems
Full Service Shop for your Antique Car needs
Richmond, MI 48063
(586) 909 - 2969
smh.restoration@gmail.com
Richmond, MI 48063
(586) 909 - 2969
Kevin Pharis
- First Name: Kevin
- Last Name: Pharis
Re: FS Model A Insert Connecting Rods / Pistons / Rings
Nice setup Seamus! Hard to tell from the pic, are those high wrist pin pistons for using full length A rod and A crank in T block?
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Seamus- PM and email sent on the pistons and rings.
