Wanted: gas tank filler
Brent
Topic author - Posts: 10
- First Name: Brent
- Last Name: Coil
- * REQUIRED* Type and Year of Model Ts owned: 1914 1917 1926 1927
I need the filler opening that the gas cap screws into for a 26-27 Tudor gas tank. If you have an old rusted tank that still has good threads for the filler neck please message me. Thanks
Karl Von Neumann
- First Name: Karl
- Last Name: VonNeumann
- * REQUIRED* Type and Year of Model Ts owned: 1916 touring 1927 tudor 1926 hotrod 1913 speedster (project) 1926 coupe (project)
- Board Member Since: 2022
Re: Wanted: gas tank filler
I think I have a junk cowl tank in storage ill have a look when im out there tmrw
Karl Von Neumann
- First Name: Karl
I did look ive got a bad tank but the neck is pretty crusty
Wingnut
- First Name: William
- Last Name: Reep
- * REQUIRED* Type and Year of Model Ts owned: 1924 roadster, 1926touring, 1926 Coupe
I have a tank I'm not going to use, someone had tried to seal it with red coat inside and a God awful slather of some rubbery sealer outside. the threaded filler neck is just fine. contact me @ three three 0Twofour12sixfour1 you can call or text. Wingnut
