Mainbearin linebore unit models A and T Ford
Gene_French
First Name: Gene
Last Name: French
Board Member Since: 2014
Post by Gene_French » Sat Feb 14, 2026 10:26 am
linebore unit for boring the mainbearings and cutting thrust surfaces on models T or A Ford mainbearings … includes 4 bearing linebore frame , boring bar and bits and radius/facing bit to cut thrust surfaces and clearance radii , false cam and locator brackets and bushings and dial indicator tool set and instructions … price $1050 plus $150 crating and shipping in lower 48 states … actual postage outside this area or international … Gene French 49519 cr.23 Nunn,Co. 80648 phone 970-581-2808
P.S.
i will be at the Duncan ,Ok. swapmeet March 26-28 ... you can save a bunce on postage and crating if you pickup there ... i would recommend that you pre-pay to assure that your unit will be available since i will only bring a small quantity of items i manufacture
Gene_French
First Name: Gene
Last Name: French
Re: Mainbearin linebore unit models A and T Ford
Post by Gene_French » Sat Mar 07, 2026 8:15 am
you can save a bunch in shipping by picking up a linebore and molds at the Duncan swapmeet ... Gene French
