For sale is one Stevens T-121 Drive Shaft Sleeve Driver. The T-121 is one of the tools Stevens included in their drive shaft overhaul tool kit. It is used when replacing the roller bearing sleeve on the drive shaft. When installed the sleeve has to be aligned with the key way for the pinion gear key, and that can be challenging because the sleeve is a driven fit on the drive shaft. This Stevens driver makes the job much easier because the notch on the end of the driver can be aligned with the key way in the drive shaft to insure the sleeve goes on properly.
This driver is in very good condition and shows very little use. Most of the sleeve drivers you find today have been used hard and the end of the driver is mushroomed over. This one is near perfect with only one small nick in the head. With care, it will provide a lifetime of service to its owner. $300 plus $9 USPS Priority Mail shipping.
FS: Stevens T-121 Drive Shaft Sleeve Driver
travis_towle
- First Name: Travis
- Last Name: Towle
- Board Member Since: 2003
Re: FS: Stevens T-121 Drive Shaft Sleeve Driver
Wow that’s crazy money. I have the puller that goes with this ~ wish I had this! Good luck!
LOCParts
Topic author - Posts: 56
- First Name: Langs
- Last Name: OldCarParts
The Stevens T-121 Drive Shaft Sleeve Driver has been spoken for.
Thank you MTFCA!
Thank you MTFCA!
