FS ---- T, TT and AA parts
26modeltt
First Name: Jack
Last Name: Leonhardt
* REQUIRED* Type and Year of Model Ts owned: 1926 Model TT Dump Truck w/ Weaver Model G 3 ton capacity wrecker boom.
Post by 26modeltt » Thu Dec 07, 2023 4:24 pm
TT 3 rear shackles $90.00, T/TT steering column $25.00, TT brake drums $60.00 pr., A spare tire brkt./mount $75.00 pr. and AA hub caps $50.00 pr. Plus shipping. Text 920-two two six-1005.
Andy ruffles
Last Name: Ruffles
* REQUIRED* Type and Year of Model Ts owned: 1912
Re: FS ---- T, TT and AA parts
Post by Andy ruffles » Thu Dec 07, 2023 5:14 pm
Hi i will take the rear shackles
26modeltt
First Name: Jack
Post by 26modeltt » Sat Dec 09, 2023 2:04 pm
Andy,
Sent you a private message, also an email to one your fellow "T" owner's "Down Under" for a possible combined shipment to Australia and save $$$$$.
Regards,
Jack
Andy ruffles
Last Name: Ruffles
Post by Andy ruffles » Sat Dec 09, 2023 6:33 pm
Jack
Do you have any truck rear Hyatt bearings as well.
26modeltt
First Name: Jack
Post by 26modeltt » Sat Dec 09, 2023 9:46 pm
Andy,
I have multiple #1019 outer axle bearings, #1050 Worm thrust bearing collars, #1051 Worm thrust ball and separator assemblies, #1046 Worm roller bearings, #1018 Axle shafter inner ball bearing assemblies, #1113 brake drums, #1048 Worm roller bearing sleeves and more. No rust/corrosion.
Regards,
Jack
Andy ruffles
Last Name: Ruffles
Post by Andy ruffles » Tue Dec 12, 2023 4:00 pm
Jack
Sent you a private message.
Regards Andy
26modeltt
First Name: Jack
Post by 26modeltt » Wed Dec 13, 2023 5:25 pm
Andy,
Sent email w/ photo attachments to you.
Thanks,
Jack
26modeltt
First Name: Jack
Post by 26modeltt » Sun Dec 24, 2023 4:41 pm
SOLD to Jeff ---- Model A Spare Tire Brackets. Thank you Jeff.
