New misc oil seal thrust washer
Melba Nolan
First Name: Melba
Last Name: Nolan
* REQUIRED* Type and Year of Model Ts owned: 23 roadster
Post by Melba Nolan » Thu Jun 23, 2022 8:27 pm
For Sale: steering gear pin set for 9/27 $2
front axle and steering castle nuts for 9/27
MBB Quadrant mounting rivets. BRASS $1
lower crankcase cover bolts 17 pcs. 9/27 $3
Head bolts High Cylinder 3 1/4" $1.75 each
Differential gear key $1.50
Fan bushing $7.50 pr. 20/27
Manifold studs and nuts 9/23 $2 each
Brass thrust washer $12 each
Brake rod support bolt and nut $4.50 pr. 14/27
Brake rod support bracket $ 14/25
Differential thrust plate $6.95 each
connecting rod and nut set $9.25
inner oil seal $20.00
All with postage to be added
Melba Nolan
First Name: Melba
Last Name: Nolan
Re: NOS misc oil seal thrust washer
Post by Melba Nolan » Sat Aug 06, 2022 10:49 pm
move to top
Melba Nolan
First Name: Melba
Last Name: Nolan
Re: New misc oil seal thrust washer
Post by Melba Nolan » Sun Sep 18, 2022 10:34 pm
move to top
Melba Nolan
First Name: Melba
Last Name: Nolan
Post by Melba Nolan » Tue Nov 08, 2022 12:24 am
move to top
