Brass Holley G carburetor
Corey Walker
First Name: Corey
Last Name: Walker
Post by Corey Walker » Mon Oct 31, 2022 5:33 pm
Probably an earlier one, 1915, because it came with hex head idle screws, all brass drain plug and spray needle. Completely disassembled and cleaned, new float, venturi, choke spring, reconditioned spray needle, float valve and test run. $195 plus $17.05 shipping. I didn’t bend the choke staple yet because if you want a double choke arm for a starter I can put one there instead. Email: wlkma9@gmail.com
Corey Walker
First Name: Corey
Last Name: Walker
Re: Brass Holley G carburetor
Post by Corey Walker » Fri Nov 04, 2022 3:11 pm
Back to top.
Corey Walker
First Name: Corey
Last Name: Walker
Post by Corey Walker » Tue Nov 08, 2022 10:45 am
Back to top.
Corey Walker
First Name: Corey
Last Name: Walker
Post by Corey Walker » Mon Nov 14, 2022 8:38 am
Back to top.
jaybee47
First Name: jay
Last Name: bolante
* REQUIRED* Type and Year of Model Ts owned: 1922 Runabout
Post by jaybee47 » Mon Nov 14, 2022 10:13 am
Hi Corey. Sent you an email. Thanks.
