For Sale 1926-27 NORS Accessory Stoplight and Switch
WaltM
First Name: Walter
Last Name: Magas
Post by WaltM » Thu Apr 20, 2023 9:46 am
No longer available
Last Name: Humble
Board Member Since: 2006
Re: For Sale 1926-27 NORS Accessory Stoplight and Switch
Post by Humblej » Thu Apr 20, 2023 10:03 am
DB is Dodge Brothers.
WaltM
First Name: Walter
Last Name: Magas
Post by WaltM » Thu Apr 20, 2023 10:08 am
Thank you, Walt
WaltM
First Name: Walter
Last Name: Magas
Post by WaltM » Thu Apr 20, 2023 11:57 am
Additional photo.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Thu Apr 20, 2023 2:10 pm
If the light isn't N.O.S., then it is nicely restored, The license plate bracket, tail light stand, and switch are correct, however with the tail light stand and switch being reproduced, it would be hard to say if they are originals or reproductions. The license plate bracket is not being reproduced at this time, to my knowledge, and the closest reproduction part to the Model T license bracket is one for a Model A Drum tail light, but they have DUOLIGHT stamped on them and still require some modification to fit the Ford or Dodge Brothers stop light made by the C.M. Hall Co. for those manufacturers. Stutz, also used a similar light, but the red glass has STUTZ molded into the glass in large block letters. Regardless of whether N.O.S. original parts or some reproduction mixed in, the fact that the light is a Dodge Brothers light, significantly reduces the value as opposed to having the correct Ford script light. Someone in another post mentioned a N.O.S. Ford light, brackets and switch for sale on EBAY. It is listed for roughly a thousand dollars more than this one, but a person would have to have more dollars than sense to pay $1500.00, even if it includes the original box.
WaltM
First Name: Walter
Last Name: Magas
Post by WaltM » Thu Apr 20, 2023 2:54 pm
Terry, thank you for all that detailed information. The light and switch were wired together with a tag. I was going by what was written on the tag "1926-1927 model T accessory taillight" Thanks again, Walt
Shannon_in_Texas
First Name: Shannon
Last Name: Helm
Post by Shannon_in_Texas » Thu Apr 20, 2023 2:55 pm
I've thought that with some very careful welding someone could convert one of the DB Type-B lights to a passable Ford version using the stamped script from a Model A horn cover like this:
https://www.brattons.com/1928-2-PIECE-S ... nfo/19950/
Post by Mark Gregush » Thu Apr 20, 2023 3:12 pm
or find a nice "Ford" marked can and sell the DB marked one.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Thu Apr 20, 2023 6:33 pm
Shannon, I personally haven't done a clone stop light, but many others have, as mentioned here on the Forum. I do have a Ford script "can" or housing that has rust out on the bottom side where the clear license plate light is located and sometime when I get around to it, I plan to try to "clone" one of my Dodge DB Type 2 lights. Cloning can be done in two different ways, but the embossed DB Type 2 logo must be hammered down flat, first.
wjmodelt
First Name: Bill
Last Name: Fedak
* REQUIRED* Type and Year of Model Ts owned: 1927 Tudor
Post by wjmodelt » Fri Apr 21, 2023 12:28 am
For the accessory can light "type B," Myers Early Dodge makes reproduction Stop Silhouette, Red Glass, and Tail Light Bezel.
Bill
