Brass Holley G carburetor
Topic author - Posts: 641
- First Name: Corey
- Last Name: Walker
Probably an earlier one, 1915, because it came with hex head idle screws, all brass drain plug and spray needle. Completely disassembled and cleaned, new float, venturi, choke spring, reconditioned spray needle, float valve and test run. $195 plus $17.05 shipping. I didn’t bend the choke staple yet because if you want a double choke arm for a starter I can put one there instead. Email: wlkma9@gmail.com
- First Name: Corey
- Last Name: Walker
- First Name: Corey
- Last Name: Walker
- First Name: Corey
- Last Name: Walker
- First Name: jay
- Last Name: bolante
- * REQUIRED* Type and Year of Model Ts owned: 1922 Runabout
Re: Brass Holley G carburetor
Hi Corey. Sent you an email. Thanks.
