Ford wrench wanted
Mike Lebsack-Iowa
Last Name: Lebsack
* REQUIRED* Type and Year of Model Ts owned: 11Torpedo, 11 Roadster, 13 Touring, 14 Roadster, 14 Touring
Board Member Since: 2008
Ford wrench wanted
Post by Mike Lebsack-Iowa » Wed Dec 07, 2022 9:41 pm
I would like to find and purchase Ford wrench #5Z-1900. It is for Model A but I know many of us have Ts and As and V8s. Please contact me at 319-4 thirty-49 ninety5. Thanks, Mike
Mike Lebsack-Iowa
Last Name: Lebsack
Re: Ford wrench wanted
Post by Mike Lebsack-Iowa » Thu Dec 08, 2022 10:53 pm
Please have a look around your tools. Thanks for checking, Mike
Post by Scott_Conger » Fri Dec 09, 2022 10:20 am
I have tons of FORD wrenches and numbers mean nothing to me...I'm a visual guy when it comes to these sorts of things...
so, here is what Mike is looking for courtesy of Worthpoint:
Mike Lebsack-Iowa
Last Name: Lebsack
Post by Mike Lebsack-Iowa » Fri Dec 09, 2022 10:23 am
Yes Sireee Scott,
That is the wrench indeed. Thanks to everyone who checks their old tool boxes for one of these. Please let me know if you have one you could part with. Mike
Post by TRDxB2 » Fri Dec 09, 2022 12:38 pm
In case you want to try an alternative method while the search is on
https://www.fordgarage.com/pages/ratchetboltwrench.htm
Mike Lebsack-Iowa
Last Name: Lebsack
Post by Mike Lebsack-Iowa » Fri Dec 09, 2022 12:56 pm
Thanks for the information. The actual wrench allows turning the crankshaft from the motor side of the radiator without going through the crank hole. The crank handle could do that. Thanks, Mike
