As seen in the attached photos. The frame is nice. It was blasted and painted 20 years ago and kept inside. There is a '26 - '27 front axle assembly and a common one. Common differential with axles but no driveshaft. '26 - '27 engine block that has had a crack repair, '26 - '27 transmission that looks decent, narrow nose engine pan, and some other miscellaneous bits. It should be a good start to something for someone.
Whole pile, one money: $350
Message me through the system with your phone number and I'll call. Thanks!
Frame, axles, and engine -- assorted, Little Rock, AR $350
Topic author - Posts: 288
- First Name: Walter
- Last Name: Higgins
- * REQUIRED* Type and Year of Model Ts owned: 1911 Open Runabout
- Last Name: Behrendt
- * REQUIRED* Type and Year of Model Ts owned: 1912 Touring, 1925 Touring
- Board Member Since: 2022
Re: Frame, axles, and engine -- assorted, Little Rock, AR $350
Are these parts still for sale? Call me at 620 two one eight 4 two 9 two. Thanks , Steve
